[SOLVED] Problem with variable renaming
nitin2003
If I have a variable names XYZ and want to create a new variable XYZ1, and somehow by mistake I named it as XYZ and pressed 'Tab' or 'Enter', projectmaker goes into an infinite loop, leaving me no other option but to kill the process and loose all my unsaved data within a template.
Attached is a screen shot of the same.
Yes i can confirm that. Some time ago faced with the same problem. Had to kill zenno through task manager as well. But that does not happens every time you enter doubles.
Please test on v5
nitin2003
Fixed for v5.0.1.0
