- Реакции
- 1 206
As bug with project directory does not appears before you have clicked Advanced editor and back is not possible to solve then probably it is possible to make some workaround ?
For example when you open any template first time when PM is started then this template could open in advanced editor already ? In this way is possible to avoid half way you have to do now...
Cheers
Cheers
