Project working in project maker but not working in zenno poster
sylon
I just made a script in project maker and executing it in project maker works perfectly (no step by step but all continuously).
After that when I go to zenno and try to run my project there it doesn't work, if I show the screen it looks like it just crashes and start again...
What can I do?? any tips??
What information do you have in Logs after that?
sylon
This is the ind of log I get...I am searching element by leftInTab atribute and as I said in project maker it always work, but here in zenno it always fails
sylon
*"this is the kind" is what I wanted to write
Error is pretty straightforward. Try to change attributes for element's search
sylon
That was the only atribute It works with as the page is pretty good on avoiding automatization and it canges ids, classes, order of fulltags etc etc but the best way for me to find the element is by position as I mentioned, and it is just wierd that it does work on project maker and not on zennoposter...
Sample is needed. Cannot say anything specific without it.
