[+] ProjectMaker was speed up.
Yes i could agree with this but only at the beginning, when you have worked just longer it lags more than anytime before...
Basically this new version starting to lag when it reach ~ 450 Mb RAM all previous versions started to lag to ~ 700 Mb RAM
Anyone else?
Performed my own test. I ran infinite loop in PM for ~1.5 hours and it didnt fail or anything.
Try to open 20 templates and then work with them.
And with lag i mean that old problem what started to appear from last build. When you click on action then you have to wait while action properties appear.
1) There's no reason to work with 20 projects at the time. Try to open 100 tabs in chrome, you will not be surprized that it will hang i bet.
2) I noticed it with C# action. Any others?
