Proxy checker problem
dariesto
After last update to version 5.11.1.0 proxy checker wont test proxies, in the left lower corner status is "Connection: connected / Proxy checking server: Not available"
in Settings>ProxyChecker settings after clicking test shows green checkmarks for both http and https availability.
In "Control" tab in ProxyChekcer in right side (Between Proxy base and Live proxies) is "Connectiong ..."
Thanks in advance for help.
Please check your antivirus and firewall programs. Looks like they block connections to proxychecking servers.
dariesto
After disabling antivirus still the same happens.
Please enable detailed log in program settings.
Then repeat the problem and run Diagnostic.exe from program folder. Attach resulted report.zip.
dariesto
Trying to upload file here but I'm getting error:
"The following error occurred
The uploaded file is empty.
report.zip"
But file is not empty, it's disk size is approx. 5.7mb
dariesto
Problem solved, antivirus programm most likely deleted Checkingprocessor.exe file
Реакции: LightWood и VladZen
LightWood
