Socks5 Problem only works with list not when set directly
  • Автор темы Автор темы nova
nova
When i use the Browser Setting to set a socks proxy it never works. I put in "socks5://11.11.11.11:9999"
The only way i got it to work is if i make it load a list then do list processing to pick the proxy which have in this format "socks5://11.11.11.11:9999" then use the set proxy. Then it works.
So is this a bug that socks5 proxy wont work when you input it directly into set proxy function in this format "socks5://11.11.11.11:9999"?
Doesn't work as expected. Ip doesn't change, see template plz. But i have found that if you restart instance, ip changes. I am sure it's a bug. Plz review it.
FireFox has bug with socks.
I suggest you to use 1 socks per execution. If you need it to be changed, restart instance.
