Sometimes and instance will execute without using a proxy
BlackSun
No matter whether the template task properties is set to "Compulsory" for proxies or whether the proxy is called for within the template and checked to have been allocated.
Sometimes and instance will execute without using any proxy. :huh:
Is there a way to avoid this?
Is this a problem with Zennoposter or perhaps a problem with certain free proxies?
Any information you can share on what might be going wrong, will be useful.
Thanks.
BlackSun
How did you detect it? I think that you use not anonymous proxy
I'm only using anonymous proxies from the proxy checker.
In the bottom left corner of every browser instance, it indicates whether or not a proxy is being used and the proxy ip and port number.
