Synchronize Problem with multithread
  • Автор темы Автор темы cashlo
cashlo
I am trying to login with a list of accounts, are there any simple way to avoid two thread to login to the same account and release the account to other thread when a thread die?
BTW, where can I ind some good source of proxy :p?
Thanks!
To avoid two threads with the same login data you need to remove the string/line with the login info from your textfile.
{-File.GetString-|-\Resources\-|-random-|-true-}
For proxies you can contact/PM me but it depends for what you need the proxies else then posting with ZP.
How do you handle this if you need to use the same info from the line several times in one thread?
I have use global deposit to set a key with this value and then use the key several times.
But it makes multi-threading not possible as the next thread will write to the same key and mess things up.
And if I would try to read the same line several times it would simply be next line on each run.
Any suggestion on how to multi-thread this kind of things?
Best,
Kandor
