Using only project maker and hardware ID
aleksa77
Hello, I using only project maker on one PC, but using it for clients, when i need check and debbug if something is wrong only on his PC. But i need to remove hardware and install again to can use project maker , I think i can not disable- enable hardware like with ZennoPoster, i need again install if want use again on old PC ?
That's because separate ProjectMaker is bound to one computer only. It's not possible to install it on 3 computer like ZennoPoster and activate/deactivate the program on one of these PC's.
