What's the difference between these 3 "Profiles" and how to save and reload them
heyupt
Hi friends,
In ZP there are three actions (windows) about profile, one is the "Profile processing" action in the tool bar (let's call it A), another is the "Current profile" in the top bar(let's call it B", the 3rd is the browser profile at the bottom bar"Let's call it C".
What's the relation between these 3 "profile"? In the A action, what data does it save and reload? Save B data or C data? And for the C, browser profile, how to save the parameter then reload them in different projects? :-)
Any kind friend could explain for me? :-)
Huge thanks!!! :-)
  • 73,5 КБ Просмотры: 118
  • 68 КБ Просмотры: 110
  • 43,2 КБ Просмотры: 107
Hi friends,
Huge thanks!!! :-)
There is only one action block - Profile processing.
Browser profile at the bottom - are the settings for generating browser profile, which will be used in zenno browser for websites.
Current profile in the top bar - is the profile which was generated according to profile settings and is currently used by zenno browser.
You can make some manulations with this current profile using Profile proessing operation - save, re-generate, change some fields, etc.
