When I add a project to ZP it won't 'run', goes straight to 'done'
christer
I've created a project in projectmaker, debugged it and am certain in works. When I add it to zennoposter to run it, it won't run. The project will be running, but it says it's done.
I'm just adding the project, selecting execution count and hitting 'run'. The project itself has a lot going on with random profiles and setting proxy there, is that a problem?
Thanks.
http://imgur.com/zK7aPgc
christer
To be clear, when I add the project and run it it goes directly to saying it's done.
Then i bet something should be in Logs folder
Реакции: christer
