Zennoposter not click sound challenge
Sheon
Hello
Today morning Zennoposter stopped clicking to open sound challenge. even all coded C# bots.
Apostol
Hello
Try it:
//Main settings
// waiting timeout
var waitTime = 1000;
// recognition attempts
var tryRecognize = 3;
// attempts to load element
var tryLoadElement = 60;
// show recognizing progress messages
var needShowMessages = false;
// need to check answer's correctness
var needToCheck = true;
// count of associations need to click in task with associations
var countAssociations = 4;
// Additional variables
// tab
var tab = instance.ActiveTab;
// congratulations, you are not robot
var success = false;
// audio file
var file = string.Empty;
// file has been deleted
var fileDeleted = true;
// answer to audio captcha
var answer = string.Empty;
// new type ReCaptcha2
var isNewView = true;
// ReCaptcha 1
var isRecaptcha1 = false;
// timeout exceeded
var timeout = false;
// error loading file
var fileLoadingError = false;
var usedURLs = new List<string>();
// task with associations
var isAssociationsTask = false;
var isFirstAttempt = true;
var coincidenceReCaptcha2Index = -1;
Action FindAssociations= () => {
    // getting task
    var associationsTask = tab.FindElementByAttribute("div", "class", "rc-text-desc-wrapper", "regexp", 0);
    if (!associationsTask.IsVoid)
        var phraseSplit = associationsTask.GetAttribute("innerhtml").Split(new []{"<span>", "</span>"}, StringSplitOptions.None);
        if (phraseSplit.Length == 3)
            var phrase = phraseSplit[1];
            if (phrase != string.Empty)
                var table = tab.FindElementByAttribute("table", "class", "rc-text-choices", "text", 0);
                if (!table.IsVoid)
                    var tableElems = table.FindChildrenByTags("td");
                    if (tableElems.Count > 0)
                        var variants = new Dictionary<string, HtmlElement>();
                        var words = new List<string>();
                        foreach(var elem in tableElems)
                            var text = elem.GetAttribute("innertext");
                            variants.Add(text, elem);
                            words.Add(text);
                        project.SendInfoToLog("Recognizing text task", needShowMessages);
                        var requestString = string.Format("{0}:{1}", phrase, string.Join(";", words));
                        var imageStr = Convert.ToBase64String(new Byte[0]);
                        var rc = ZennoPoster.CaptchaRecognition("CapMonster2.dll", imageStr , string.Format("Task={0}&CapMonsterModule=ZennoLab.ReCaptchaAssociation", requestString));
                        var cmAnswer = rc.Split(new [] {"-|-"}, StringSplitOptions.RemoveEmptyEntries)[0];
                        if (string.IsNullOrEmpty(cmAnswer) || cmAnswer == "sorry")
                            var reload = tab.FindElementByAttribute("button", "id", "recaptcha-reload-button", "regexp", 0);
                            if (!reload.IsVoid)
                                reload.Click();
                            return;
                        var answers = cmAnswer.Split(new []{";"}, StringSplitOptions.None);
                        for (int i = 0; i < countAssociations; i++)
                            if (i < answers.Length)
                                variants[answers[i]].Click();
                                System.Threading.Thread.Sleep(500); //pause
// Searching audio button element
Action TryOpenAudioForm = () => {
    for (int k = 0; k < tryLoadElement; k++)
        var audioButton = tab.FindElementByAttribute("button", "id", "recaptcha-audio-button", "regexp", 0);
        // if found
        if (!audioButton.IsVoid)
            // press button
            audioButton.Click();
            tab.WaitDownloading();
            break;
        System.Threading.Thread.Sleep(waitTime); // pause
        if (k == (tryLoadElement - 1)) timeout = true;
Action OpenAudioTask= () => {
    project.SendInfoToLog("Loading audio task", needShowMessages);
    if (isNewView)
        //checking task type in the form
        var task = tab.FindElementByAttribute("div", "class", "rc-imageselect-desc-wrapper", "regexp", 0);
        if (!task.IsVoid) TryOpenAudioForm(); // graphic task has been found, then loading audio
    else
        var elem = tab.FindElementByAttribute("input:submit", "class", @"fbc-button-audio\ fbc-button", "regexp", 0);
        if (!elem.IsVoid) elem.Click();
        var errorElem = tab.FindElementByAttribute("div", "class", "fbc-message", "regexp", 0);
        if (!errorElem.IsVoid)
            var attr = errorElem.GetAttribute("innertext");
            if (attr.Contains("Please enable JavaScript and/or update your browser to get an audio challenge"))
                throw new Exception("Can't open audio form, try to change userAgent");
Action VisibleIndexReCaptchaDefinition= () => {
    var recaptchaElementsGroup = tab.FindElementsByAttribute("div", "class", "recaptcha-checkbox-checkmark", "regexp");
    int length = recaptchaElementsGroup.Elements.Length;
    if (length == 1)
        coincidenceReCaptcha2Index = 0;
        return;
    for(int i = 0; i < length; i++)
        var element = recaptchaElementsGroup.Elements[i];
        if (!element.IsVoid)
            int x = element.DisplacementInTabWindow.X;
            int y = element.DisplacementInTabWindow.Y;
            var suspectVisibleElement = tab.GetElementFromPoint(x, y).DisplacementInTabWindow;
            if (x == suspectVisibleElement.X && y == suspectVisibleElement.Y)
                coincidenceReCaptcha2Index = i;
                break;
// Identifying ReCaptcha version
Action NotRobotClick= () => {
        // searching coincidence index of recaptcha elements
        VisibleIndexReCaptchaDefinition();
        if (coincidenceReCaptcha2Index < 0)
            // checking if ReCaptcha 1 audio button exists
            HtmlElement r1 = tab.FindElementById("recaptcha_switch_audio");
            if (!r1.IsVoid)
                r1.Click();
                isRecaptcha1 = true;
                break;
            // checking ReCaptcha2 type
            if (!elem.IsVoid)
                isNewView = false;
                break;
        else
            // searching "I'm not robot" checkbox
            var notRobot = tab.FindElementByAttribute("div", "class", "recaptcha-checkbox-checkmark", "regexp", coincidenceReCaptcha2Index);
            // if found
            if (!notRobot.IsVoid)
                // checking checkbox
                notRobot.Click();
                // pause
                // if entering captcha is not required
                var check = tab.FindElementByAttribute("div", "class", "recaptcha-checkbox-checkmark", "regexp", 0);
                if (!check.IsVoid)
                    if (check.OuterHtml.Contains("style=\"\""))
                        success = true;
                        break;
                // waiting when form will be loaded
                for (int j = 0; j < tryLoadElement; j++)
                    var loadedForm = tab.FindElementByAttribute("div", "class", "primary-controls", "regexp", 0);
                    if (!loadedForm.IsVoid) break;
                    else System.Threading.Thread.Sleep(waitTime); // waiting when element will be loaded
                    if (j == (tryLoadElement - 1)) timeout = true;
                break;
// Downloading mp3 file
Action GetAudioFile= () => {
    var href = String.Empty;
    // getting audio task
        if (isRecaptcha1)
            var audioChallenge = tab.FindElementByAttribute("a", "id", "recaptcha_audio_download", "text", 0);
            // if found, getting link to audio file
            if (!audioChallenge.IsVoid)
                href = audioChallenge.GetAttribute("href");
                break;
        else
            if (isNewView)
                if (isFirstAttempt)
                    isFirstAttempt = false;
                else
                    if (!reload.IsVoid)
                        reload.Click();
                var audioChallenge = tab.FindElementByAttribute("a", "class", "rc-audiochallenge-download-link", "regexp", 0);
                    break;
                else
                    isAssociationsTask = true;
                    return;
                System.Threading.Thread.Sleep(waitTime); // waiting when form will be loaded
            else
                var audioChallenge = tab.FindElementByAttribute("audio", "class", "fbc-audio-controls", "regexp", 0);
                    href = audioChallenge.FindChildByAttribute("source", "src", ".mp3", "text", 0).GetAttribute("src");
                    href = "https://www.google.com" + href;
                    break;
    foreach (var usedUrl in usedURLs)
        if (usedUrl.Contains(href))
            throw new Exception("new audio file is absent");
    usedURLs.Add(href);
    project.SendInfoToLog("Downloading audio file", needShowMessages);
    try
        var proxy = instance.GetProxy();
        var respType = ZennoLab.InterfacesLibrary.Enums.Http.ResponceType.File;
        var timeoutRequest = 30000;
        var cookies = instance.GetCookie("google.com", true);
        var userAgent = project.Profile.UserAgent;
        var maxRedirectCount = 1;
        var downloadPath = project.Directory + "\\audiofiles";
        file = ZennoPoster.HttpGet(href, proxy, "UTF8", respType, timeoutRequest, cookies, userAgent, false, maxRedirectCount, null, downloadPath);
        fileDeleted = false;
    catch (Exception ex)
        throw new Exception("Failed to download audio file");
Action Recognize= () => {
    project.SendInfoToLog("Recognizing", needShowMessages);
    try
        if (!File.Exists(file))
            fileLoadingError = true;
            fileDeleted = true;
            return;
        var bytes = File.ReadAllBytes(file);
        if (bytes.Length < 1024)
            return;
        string str = Convert.ToBase64String(bytes);
        var rc = ZennoPoster.CaptchaRecognition("CapMonster2.dll", str, "CapMonsterModule=ZennoLab.AudioReCaptcha&ParallelMode=true");
        var split = rc.Split(new [] {"-|-"}, StringSplitOptions.RemoveEmptyEntries);
        if (split.Length > 0)
            answer = split[0];
        if (answer.Contains("133193320491090004119440")) throw new Exception("Your IP was banned!");
    finally
        if (File.Exists(file))
            File.Delete(file);
            fileDeleted = true;
Action InputAnswer= () => {
    if (!String.IsNullOrEmpty(answer) && answer != "sorry")
        project.SendInfoToLog("Inserting answer", needShowMessages);
        HtmlElement audioAnswerInput = null;
        // searching answer input field
        if (isRecaptcha1)
            audioAnswerInput = tab.FindElementByAttribute("input:text", "id", "recaptcha_response_field", "text", 0);
        else
            if (isNewView) audioAnswerInput = tab.FindElementByAttribute("input:text", "id", "audio-response", "regexp", 0);
            else audioAnswerInput = tab.FindElementByAttribute("input:text", "id", "response", "text", 0);
        // if found
        if (!audioAnswerInput.IsVoid)
            // inserting answer
            audioAnswerInput.SetValue(answer, "None", false);
        // pause
    else throw new Exception("Answer not received");
// Verifying
Action SubmitAnswer= () => {
    // searching "Verify" button
    HtmlElement apply = null;
    if (isNewView) apply = tab.FindElementById("recaptcha-verify-button");
    else apply = tab.GetDocumentByAddress("0;_0").FindElementByTag("form", 0).FindChildByAttribute("input:submit", "fulltag", "input:submit", "text", 0);
    if (!apply.IsVoid) apply.Click();
    // pause
// Checking if answer is correct for old ReCaptcha
Action CheckOldView= () => {
    // checking if there is recognition mistake
    HtmlElement he = tab.GetDocumentByAddress("0;_0").FindElementByTag("form", 0).FindChildByAttribute("div", "class", "fbc-error", "regexp", 0);
    if (!he.IsVoid)
        return;
    string txt = string.Empty;
    // searching text to insert
        HtmlElement heGetText = tab.FindElementByAttribute("textarea", "dir", "ltr", "regexp", 0);
        if (!heGetText.IsVoid)
            txt = heGetText.GetAttribute("value");
            break;
        else
            continue;
    // searching where to insert text
        HtmlElement hePutText = tab.FindElementByAttribute("textarea", "id", "g-recaptcha-response", "regexp", 0);
        if (!hePutText.IsVoid)
            hePutText.SetValue(txt, "None", false);
            break;
        else
            continue;
    // pressing "Verify"
        var submit = tab.FindElementByAttribute("input:submit", "fulltag", "input:submit", "regexp", 0);
        if (!submit.IsVoid)
            submit.Click();
            break;
        else
            continue;
    success = true;
// Checking if answer is correct for ReCaptcha 2
Action Check= () => {
    project.SendInfoToLog("Verifying answer", needShowMessages);
    var recaptchas = tab.FindElementsByAttribute("div", "class", "recaptcha-checkbox-checkmark", "regexp");
    if (recaptchas.Count == 0)
        success = true;
        return;
        var checkAnswer = tab.FindElementByAttribute("div", "class", "recaptcha-checkbox-checkmark", "regexp", coincidenceReCaptcha2Index);
        if (!checkAnswer.IsVoid)
            if (checkAnswer.OuterHtml.Contains("style=\"\""))
                success = true;
            else
                success = false;
            return;
// Checking "I'm not robot" checkbox
NotRobotClick();
if (success) return "ok";
// trying to recognize ReCaptcha
for (int i = 0; i < tryRecognize; i++)
    if (!isRecaptcha1) OpenAudioTask();
    if (timeout) break;
    GetAudioFile();
    if (timeout) break;
    if (isAssociationsTask)
        FindAssociations();
    else
        Recognize();
        if (fileLoadingError)
            continue;
        if (timeout) break;
        InputAnswer();
        if (timeout) break;
        if (!fileDeleted)
                File.Delete(file);
                fileDeleted = true;
        if (isRecaptcha1) return "ok";
    SubmitAnswer();
    if (!needToCheck) return "ok";
    if (timeout) break;
    if (!isNewView) CheckOldView();
    else Check();
if (timeout) throw new Exception("Loading element timeout is exceeded");
else throw new Exception("Not recognized, Attempts to recognize were ended, before the response was received");
Реакции: Sheon
Sheon
Try it:
//Main settings
// waiting timeout
// tab
// audio file
// ReCaptcha 1
// timeout exceeded
    // getting task
                if (!table.IsVoid)
                            words.Add(text);
                            if (!reload.IsVoid)
                                reload.Click();
                            return;
        // if found
            // press button
            break;
    if (isNewView)
    else
    if (length == 1)
        return;
                break;
            if (!r1.IsVoid)
                r1.Click();
                break;
            if (!elem.IsVoid)
                isNewView = false;
                break;
        else
            // if found
                notRobot.Click();
                // pause
                if (!check.IsVoid)
                        success = true;
                        break;
                break;
        if (isRecaptcha1)
                break;
        else
            if (isNewView)
                if (isFirstAttempt)
                else
                    if (!reload.IsVoid)
                        reload.Click();
                    break;
                else
                    return;
            else
                    break;
    usedURLs.Add(href);
    try
    try
            fileDeleted = true;
            return;
            return;
            answer = split[0];
    finally
            File.Delete(file);
            fileDeleted = true;
        if (isRecaptcha1)
        else
        // if found
            // inserting answer
        // pause
// Verifying
    // pause
    if (!he.IsVoid)
        return;
            break;
        else
            continue;
            break;
        else
            continue;
        if (!submit.IsVoid)
            submit.Click();
            break;
        else
            continue;
    success = true;
        success = true;
        return;
                success = true;
            else
                success = false;
            return;
NotRobotClick();
    if (timeout) break;
    GetAudioFile();
    if (timeout) break;
        FindAssociations();
    else
        Recognize();
            continue;
        if (timeout) break;
        InputAnswer();
        if (timeout) break;
        if (!fileDeleted)
                File.Delete(file);
                fileDeleted = true;
    SubmitAnswer();
    if (timeout) break;
    else Check();
Yeah this one clicks the audio challenge but it doesnt send it to capmonster
I think we will update snippet for audio recaptcha2 tomorrow, please wait.
Реакции: PHaRTnONu
