Zeno - Background process problem
nitroy2k
Hey guys,
I have updated zeno to latest version, and one problem I noticed
When my zenno iz working in background in project Maker or in Poster it interupts my work..
For example
ProjectMaker if I don't minimze it it will always turn that window on when he does next step that was not an issue before..
I could put it on my 2nd screen and watch it as it works.. Now I can't do that I have to minimize it...
Also during writting of this post i had to click 20 times in this field so i can write post as it always takes me out of the window and I have to click it does not take me from page just my pointer you will see what happens in next few secconds of my writting
Here is video..
http://screencast-o-matic.com/watch/coevXIeNgp
Now everything was in PorojectPoster..
How to resolve this problem ? Is there problem in my settingss or is it up to Zeno ?
Do you use drag and drop in project?
nitroy2k
No no drag and drop, it does that on any field on project I run..
nitroy2k
At this moment is twitter posting, download image, rename it, move it, upload, tweet with description and tags..
So basically if i understand you correctly the problem that you loose focus in any other applications while zenno is running, correct?
nitroy2k
Yes exactly
please send your project to support@zennolab.com in order to check which action affect this
+ include information how you run it (how many threads, how many instances per process (from settings)
nitroy2k
