[SOLVED] Anonymity problem
akash
How do you set proxy there? Inside the project or in ZennoPoster. And do you set proxy only once? Are they private? Gateway?
im setting proxies from a text file in the template. browser settings -- set proxy. i set it once at the beginning of the template. each instance is using a different proxy (from what it's showing in the instance window on the bottom left side)
You should test it with the new build.
dmarked
How to download the latest build, all I get is a commingsoon.txt file with "No such file" inside it ?
dmarked
roadhog
Where do you get 4.5, I don't see it in my downloads area?
If you got not expired updates subscription it is in userarea.
roadhog
makes sense, kind of.
cloudattack
So is the anonymous issue solved yet?
Would be bad if my accts get banned from revealing real IPs. Saw above that its fixed, but can anyone verify that its back to normal?
This problem is solved.
mark leenheer
I will write an article in a few how to proper register an accounts to avoid bans end etc.
Solved or not I would still love to see this information to help me make better templates ;-)
1) Must we still close/reboot instance every execution to completely clear cash?
2) is it necessary to use public DNS to avoid detection (if so how do we do this?)
3) Must we disable flash?
mark leenheer
mark leenheer
mark leenheer
darkdiver сказал(а):
I mean you should search in google pinterest, then click on the first link to visit pinterest with google referer, and then click "join pinterest"
You should not start registration from visiting _https://pinterest.com/join/signup/ it gives you a huge point to ban as bot registration..
When you say this are you saying that the option to add in a referrer in the goto url tab is not sufficient or as effective as really visiting the search engine or referrer site?
