Determine wether project is running in ZennoPoster or ProjectMaker
  • Автор темы Автор темы Maddis
Maddis
Is there a way to determine this?
Sorry, I should have explained it in more detail. I needed to have a different set of variables while testing in Project Maker so needed to check programmatically.
I think this will work:
// Check Running Environment
string Environ = project. Context.ToString();
if (Environ.Contains("Manipulator"))
Running In ZennoPoster Mode
project. Variables["project_HomeFolder"]. Value = ("D:\\VM's\\PC\\Shared\\Richard Monnier");
project. SendInfoToLog("Runing in ProjectMaker mode", true);
else
Running In ZennoBox Mode
return 1;
You can save variables in profile file, maybe that helps. So you can load different profile when you run in PM.
You can also get program path and then regex what program name is:
return AppDomain.CurrentDomain.BaseDirectory;
Реакции: Maddis
