Emulation Does Not Work With IPv6 Proxies
  • Автор темы Автор темы MarckyD
MarckyD
I have tried using a proxy that generates IPv6 proxies. Just to be clear I am not talking about proxies formated in IPv6 format, I'm talking about proxies who's IP address are IPv6 ip's.
So for example the proxy is that is entered into zennoposter is: 88.24.22.11:9000 and when you go to a site like iplocation.com you'll see the IPv6 address: 2800:117:1:5::1f
If anyone of these is checked, the proxy will fail to set:
96547
This does not happen when I use proxies that generate IPv4 IP addresses. It only happens when I use proxies that generate IPv6 IPs.
Реакции: zenewbie
Yes, I noticed the same.
This means not a good or maybe overused proxy. It does not respond and does not give output IP.
Hi Vlad, the proxy is my own 4G mobile proxy. I'm using my own 4G modem so I know the proxies can't be overused especially since the IPv6 pool I'm using has over 1 nonillion IPs.
When running the IPv6 port proxy it runs perfectly, just like the IPv4 port proxy, I can provide you with the proxy so that you can test on your end? Or maybe you can advise me as to what needs to be done/changed on my end?
If you give me test proxy, that would be nice
No problem, can you send me a private message so I can send you the proxy details? or do you have a preferred email?
My ipv6 proxy is excellent, and it worked BEFORE version 7.7.1 perfectly (I had these proxies in use for months without problems until 7.7.1.0 came along), how do you explain that?
The proxy maybe worked, but there could be WebRTC leak on your proxy. Now proxy is set only when WebRTC is properly emulated.
