Help With Recaptcha
  • Автор темы Автор темы MarioBros
Fixed/ Поправиленная версия
Подскажите, пожалуйста, где нужно дописать параметр "id_constructor=23" в коде примера, чтобы не выскакивала ошибка превышения размера каптчи в 100кб.
Is it possible to use Antigate or DeathbyCapacha for this as well?
Deathbycaptcha use different approach (it use coordinates as answer)
I suggest to use rucaptcha
Реакции: zennoman
I have got it to work with 2captcha the issue is they are to slow. Allot of the times the images times out due to no answer then answer comes after.
Should there not be an easy way to convert cordinates to the images places? for example make a square and if the cords are within the squre = 1 (if its the first picture) etc
Or just use a simple mouse emulation?
Slow work of rucaptcha can't be solved with any manipulation. You can try capmonster2 to solve these captchas :)
Is there any documentation on solving recaptcha v2 in English?
