How to drag and drop elements? Help!
cesario678
Guys, I have a question about how to drag and drop elements. For example, I'm editing videos online, so I upload my images there. How do I go to the image, place my cursor over it, and drag it to where I want?
Can someone help me? If anyone has a piece of script to give me an idea, I would really appreciate it.
Thanks!
Not sure if i understand you right. But drag and drop function in zenno is meant to work with sites like weebly where there is drag-and-drop interface. You seem to think about dragging and dropping images from your computer into webpage, right? If so, then this is not possible by default zenno functions. For that you need to use file upload function.
130229
Реакции: cesario678
cesario678
So that’s exactly it! I need to drag elements. For example, in CapCut, which is a video editor, I click and upload the images I want. Then, I need to drag them into my project.
Is this not possible in any way?
