- Реакции
- 0
Hey,
I have about 200 projects in ZennoPoster each running once an hour, I usually run about 20 at the same time but in the last month this seemed not to work anymore as I cannot follow anyone else for one reason or another. The projects follow when there is 1-3 threads running but once that is exceded they will not follow anyone anymore.
The only issue I think of is the fact that I copied my main project in 200 copies of it, I also might think that there is a setting that I can't find or see.
What do you think the issue is?
Thank you.
Thank you.
