If I use normal click while emulating mobile, does it work?
  • Автор темы Автор темы cesario678
cesario678
I would like to know if I set ZennoPoster to emulate mobile phones, and somewhere on a site I use the (click) function instead of (touch), does it generate a touch click or to appear as a mobile phone do I need to specifically use the (touch) function? I want to know this because I would have to create 2 separate scripts, one for mobile and another for desktop if there's a difference. Thank you for the help.
If you use click action in mobile browser, it will be detected by target website.
So, you should create touch action.
