- Реакции
- 257
Currently testing the latest build from v7.7.1.0 and wondering if this is the correct behaviour: When I run a project (e.g. called "Main") that does NOT use a browser and this project has a nested project (e.g. called "External") that has browser enabled in the project settings, then I can NOT see any instance in the "Instances" window of ZP when "External" is running.
To mention: I have of course enabled "Open browser if necessary" in "Main"
Is this the intended behaviour and if yes how can I enable that I see the browser window in "Instances" of ZP while "External" was called from "Main" and is running?
