My devices are visible in Project Maker, but when I try to run the devices collectively in Enterprise, they are not visible.
Takarimasu66
I can see my devices in ProjectMaker, but when I try to run them in bulk, these devices do not appear in the Zennodroid Enterprise program. What could be the reason?
135840
To resolve this issue, please close the program and kill all adb.exe processes in Task manager.
Then run ZennoDroid Etnerprise again.
135886
Çalışmıyor. Denedim. Cihazı bu şekilde tanıttım ama Project Maker hata vermiyor. Enterprise da hata veriyor, Cihaz Listesi hatası veriyor ve Enterprise cihazlarını görmüyor. Garip olan şu ki, destek ekibine yazıyorum ve destek ekibi hub olduğu için cihazı göremediğini söylüyor. Doğrudan bağlantı kuruyorum ama yine de cihazımı göremiyor. Projeyi başlattığımda Project Marker düzgün çalışıyor ama hata veriyor.
There are 3 hubs and 15 devices, sir. When I wrote to your support, it said there are 80-100 devices that manage them. I don't think I did anything wrong with my program. My devices are not visible in the enterprise version.
Please enable detailed log in program settings, close both applications, then start PM and start ZDE.
After that, run Diagnostic from program settings and send us created report.zip.
I don't know how to do this. Can you contact me via Telegram? I can give you detailed information @simithwillieams23
The issue was in adb connect string in some external dll component. It is resolved now.
Yes, my devices are visible now. I will try to run my program in bulk. I will let you know again, sir, but it took a lot of effort. Thank you again to the friend who provided the connection for solving my problem. :bo:
