Problem starting up.
  • Автор темы Автор темы DopedUp666
I am able to create android 9 and run it from memu manager, but in PM it still does not appear
99277
The stranger thing.. If I leave it to "random" it is able to create android 9 , so the problem is only with the dropdown selection
99278
Deleted all the files from /images/96 folder
In multi memu clicked on "New" , android 9
Then it said 'downloading from internet' and files appeared in /96 folder
Re-installed ZD 2.3.1
Restarted PC
Still missing ¯\_(ツ)_/¯
Restarted PC
He-e-e-y:-)
I talked about zennodroid 2.3.2.0 version and gave the link in the initial post.
Реакции: myndeswx
Hello @VladZen, could you share the version 2.3.2.0 for zennodroid lite ? Your link is for the pro version, or can I use it also ?
I'm also having issues, thanks
Thank you, for now I rolled back to ZennoDroid 2.2.4.0
i have the same problem and update to 2.3.2.0 does not fix it, still open the memu player but its not detected on zennodroid
yes i have version 8.0.6, also tried other versions and same result, does not work
As you can see here it opens memu player instance in a very tiny screen and keeps Initializing forever in zenno. I tried everything, resinstall zenno, reinstall memu multiple versions, all workarounds in this thread and nothing works.
    35,3 KB · Просмотры: 241
DopedUp666
did you ever fix the starting out problem , im having the same exact problem as yours , can someone please help fix this issue
  • logfile.txt
    logfile.txt
    477 байт · Просмотры: 237
i have same problem starting up vm on zennodroid , does any one have a fix
  • logfile.txt
    logfile.txt
    477 байт · Просмотры: 241
here is diagnostic with new version
