Project Maker crashes while using Chromium
  • Автор темы Автор темы tharrkun
tharrkun
Every time I use Run Instance to work with Chromium it only takes a minute or two for Project Maker to crash. It just closes and that's it.
I doubt it's a resource thing, since I can easily run up to 75 instances of CEF at once.
I'm running 7.7.3.0 on Windows 11.
Chromium and Windows 11... I bet it's also version 22H2?
That's correct. Was just reading about the issues with ZP on Chromium with Windows 11 and I guess I'll have to stick to CEF unfortunately, as I don't see the point rolling back to Windows 10 :|
BTW it's interesting that there are still compatibility issues. Windows 11 has been around since October 2021, if I remember correctly...
We are currently fixing it. This is only the issue on 22h2.
ZennoPoster should work properly on Windows 11 21h2 version.
There is still such a problem with using Chromium on Windows 11 22h2
The version of ZennoPoster is 7.7.4.0
It crashes when I try to work with extensions
It has passed two months. Is there a chance to fix it?
ZennoPoster 7 is not compatible with this system. We are no able to fix it currently.
This should be fixed in version 8.
