Running a Project within a Project but each project requires different browsers?
  • Автор темы Автор темы JIMBOB
JIMBOB
I have 2 projects that run one after another.
The first project only works in Firefox and the other project only works in Chrome.
Is there a way I can run them one after another without having to manually change the Instance browser settings?
Thank you.
Okay, it doesn't seem to work with project in project because I believe whatever the browsers specs are for the first project is, it uses the same browser specs for the next project which means it won't work properly.
My question is, is there a way to automatically run one project after another without using project in project?
Each project works one after another if I manually run each individually as there own project in zennoposter, but what I'd like to do is once the first project finishes, the second project starts? is this possible? I have hundreds of project setups like this so I really need to work out how to make it work automatically.
Thank you.
