Seeking Help: Copy Button Not Working in GPT Interface on Zeno
Pierre Paul Jacques
Активный пользователь
Hi everyone!
I am a beginner with Zeno and I would appreciate some help :-)
I have a simple question: Why, when I click on the Copy button in GPT, doesn't it copy? (If I manually copy some text, it works)
Thanks in advance!
112746
This button copies text to clipboard probably.
If you wish to copy text from some field to variable, you should use Get value action in zennoposter
Реакции: Pierre Paul Jacques
Pierre Paul Jacques
Thank for your reply VladZen,
Yes this button copy the clipboard so from what i understood Zeno don't copy the GPT text to clipboard because i was using click action and
"it is just a click" without way it get the value associate to this click.
I didn't succeed yet to get the value i want ( the text generate by gpt)
But by parsing it work :
(?<=<div\ class="markdown\ prose\ w-full\ break-words\ dark:prose-invert\ light"><p>).*(?=</p></div></div></div>)
112750
My goal is to have a liste of article write with GPT from a list of Keyword,
i guess is something basic for most of you,
If you have any ressource, link, video about this it will be great!
