And I am getting these errors after updating to 5.9.8.1 when I save a profile or load a profile (sometimes, not always).
The number of zpdata and zpcookie files is much larger than the number of these errors, so it's not 1 to 1 relationship.
All I do is first to try to load profile. If it fails, then log in to save a profile.
a zpprofile file is generated as expected. But with it, a number of zpdata and zpcookie files are also created. After running the project for a few days, the folder will become full of zpdata and zpcookie files.
@Cyrix mate, can you send me example of template that generate this error in your logs?
"The output byte buffer is too small to contain the encoded data, encoding 'Chinese Simplified (GB2312)' fallback 'System.Text.InternalEncoderBestFitFallback'. "
